2 members (moparguy, 51sub), 103 guests, and 4 robots.
Topics128,070
Posts1,055,892
Members48,428
#462116 10/16/2008 7:12 PM
Apprentice
Apprentice
I am going to be transporting a half ton frame with the entire drive line attached (engine, tranny, rearend), but the body is stripped off. Does anybody know the approx. weight of the truck without the body?
Francis
Wheels and tires too?
My guess is around 2,000 pounds, but figure wheels and tires are 50 pounds each so they make a big difference.
I'm in the middle of a frame-off restoration on a '49 3100. I've been handling and moving these parts individually for the past year. Following is an educated guess...
Frame only: 300 lbs (two men can lift and move it)
Engine: 400 lbs
Transmission: 150 lbs (I can lift and move it myself)
Torque tube and drive shaft: 150 lbs. (same as above)
Rear differential, axle, and axle shaft: 200 lbs. \
Total weight: 1200 lbs
4 Wheels, leaf springs, and front axle: add another 300 lbs.
Total rolling chassis weight is about 1500 lbs.
Apprentice
Apprentice
Yes, it will have wheels and tires on it as well; a complete rolling chassis. I was going to guess it was around 1500 lbs. Thanks for confirming!
If anyone thinks this estimate is way off, please let me know.
The motor is somewhat more than 400 pounds.
Use the same approach to estimating the weight of the sheetmetal and substract that from 3300 or so total... Bed about 300 because two guys can lift it. Front clip about 300, again because two guys can lift it. Cab takes four guys so call it 600 pounds. So take 1200 from 3300 and you have 2100 pounds.
I'll stick with my estimate closer to 2000 pounds. You would sure be better off preparing for too much rather than too little...
Not sure if it helps, but we pulled my 49 3100 with a flat bed car trailer and a 1/2 Dodge with a 318 motor and it did fine going 300 miles.
Are you worried about trailer weight?
I would say the motor alone weighs 700.I could be wrong,would'nt be the first time .
1951 3100 Chevrolet
yahooed weight of chevy 235 and got 615 to 630 lbs. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
The 600+ neighborhood is what I would expect for the motor. Don't forget the bellhousing, flywheel and clutch when estimating the weight of this stuff too.
I'll be disappointed if somebody out there doesn't take a bathroom scale into the garage and weigh one wheel at a time. Curious minds want to know.
Apprentice
Apprentice
So, am I safe in assuming around 2000 lbs???
