11 members (FAST55, panel fan, Wayne67vert, Gdads51, Lightholder's Dad, gswbbc, 48jim1ton, frogfarmer, tclederman, Ponchogl, 1 invisible), 106 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#462529 10/17/2008 8:39 PM
Doing some brake work on my 1951 and find the brake block (on the frame) has a stripped out fitting from the master cylinder. NAPA does not have - can't find it in Jim Carters, Chevys of the 40's, or any place else. This block bolts through the frame using a 3/4 nut. Keeps the lines very secure. Any recommendations? Junk Yard? Thanks, BW
R. Wyant #462551 10/17/2008 11:13 PM
Junk yard, or post a wanted add in the swap meet section.
Grigg
Grigg #462576 10/18/2008 1:15 AM
Is it this from The Filling Station?
Part #SA-307
Type: TRK Model: ALL Year: 1947-1957 Price $28.95
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z5AAEZV~P28.95~~~~S2HN176NWW71991511835a~Z5Z5Z5~Z5Z5Z50000014x
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Thanks Sam, I was looking thru my reciepts for that fitting. I replaced all of the fittings when I did my brake rebuild. It sure paid off in a nice tight brake system that has worked flawlessly for a couple of years now with only minor brake adjustments to compensate for normal wear.
Denny G
Denny G
Sandwich, IL
