8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Doing some brake work on my 1951 and find the brake block (on the frame) has a stripped out fitting from the master cylinder. NAPA does not have - can't find it in Jim Carters, Chevys of the 40's, or any place else. This block bolts through the frame using a 3/4 nut. Keeps the lines very secure. Any recommendations? Junk Yard? Thanks, BW | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Junk yard, or post a wanted add in the swap meet section.
Grigg | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Is it this from The Filling Station? Part #SA-307 Type: TRK Model: ALL Year: 1947-1957 Price $28.95 http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z5AAEZV~P28.95~~~~S2HN176NWW71991511835a~Z5Z5Z5~Z5Z5Z50000014x
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Sam, I was looking thru my reciepts for that fitting. I replaced all of the fittings when I did my brake rebuild. It sure paid off in a nice tight brake system that has worked flawlessly for a couple of years now with only minor brake adjustments to compensate for normal wear. Denny G
Denny G Sandwich, IL
