| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46254 06/13/2005 5:00 PM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | I need a new flywheel ring gear for my '54 235-139 tooth. I can't seem to find any major parts outlet that can get me one. I can get a 168 tooth ring cheap, though, so I'm thinking about putting a later starter in. Is it possible to convert the starter for the 139 tooth gear to 168 tooth? Anyone know where I can get a 139 tooth gear relatively cheaply? Thanks a bunch, fellows. | | |
#46255 06/13/2005 5:38 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tyler, GregH posted a few years ago that he got a 139 tooth ring gear (part #838177 37\54) from Chevs of the 40s. Search on "ring gear" after setting the year to "1954". Tim | | |
#46256 06/13/2005 8:41 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | You will pay a lot for anything from Chevs of the 40s. If you have time, I would start haunting the local swap meets. | | |
#46257 06/14/2005 2:20 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can just put it o up-side-down if it's not to bad. I did that with my 1955 235 ring gear, not sure how many teeth, no problems after a few years. I kind of think that the gear has chamfered teeth on one side and not on the back, it id not seem to matter when I turned mine over, works great. | | |
#46258 06/14/2005 1:52 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | LMC truck lists ring gears in their catalog.
Mike Barnes 1950 GMC 1-ton pickup
