4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
#462540 10/17/2008 9:44 PM
Has anyone ever run small (3/8") lines to oil filter on thier 261? I have a bad #$% filter mount from a harley, but it has 1/8 pipe threads, 3/8 in hose max. I sure wanna run it. BTW I got my 261 off the 'bay for 300.00, running perfect, I also have a t-5 fenton intake and speedway headers. Also mallory dual point with vacuum, and an 848 shaved .040" with a fresh valve job. It's all going into my 1962 fleet/ short big window truck, WHOO-HOO!
Who is John Galt?
Is your 261 set up for a full flow or bypass oil filter? The full flow filter needs at least 3/8 pipe thread fittings. The 1/8 fittings are used with the bypass filter. I believe that the late 261s that came with full flow filters used 1/2 pipe fittings.
Sounds like you have a great engine. Welcome to the Bolt!
Hoyt
Hi, It has 1/2 fittings, it came out of a 1960 Helm's bakery panel. I was hoping someone has ran the smaller lines on one. But, I kinda figured I'd have to use bigger. Thanks.
Who is John Galt?
I used 1/2" stainless steel lines with double flare brass fittings and mounted the filter directly on the motor so there was no issue with the lines being flexed as they "ride" with the engine. Have some pics in the engine rebuild album on the link below. Good luck!
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
49 geezer,
In which album are the 1/2" stainless steel lines? Album name and picture # would help the search.
Picture #65 in Engine Rebuild?
Thanks, Tim
