| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Has anyone ever run small (3/8") lines to oil filter on thier 261? I have a bad #$% filter mount from a harley, but it has 1/8 pipe threads, 3/8 in hose max. I sure wanna run it. BTW I got my 261 off the 'bay for 300.00, running perfect, I also have a t-5 fenton intake and speedway headers. Also mallory dual point with vacuum, and an 848 shaved .040" with a fresh valve job. It's all going into my 1962 fleet/ short big window truck, WHOO-HOO!
Who is John Galt?
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Is your 261 set up for a full flow or bypass oil filter? The full flow filter needs at least 3/8 pipe thread fittings. The 1/8 fittings are used with the bypass filter. I believe that the late 261s that came with full flow filters used 1/2 pipe fittings.
Sounds like you have a great engine. Welcome to the Bolt!
Hoyt | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Hi, It has 1/2 fittings, it came out of a 1960 Helm's bakery panel. I was hoping someone has ran the smaller lines on one. But, I kinda figured I'd have to use bigger. Thanks.
Who is John Galt?
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I used 1/2" stainless steel lines with double flare brass fittings and mounted the filter directly on the motor so there was no issue with the lines being flexed as they "ride" with the engine. Have some pics in the engine rebuild album on the link below. Good luck! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 49 geezer,
In which album are the 1/2" stainless steel lines? Album name and picture # would help the search.
Picture #65 in Engine Rebuild?
Thanks, Tim
