7 members (Otto Skorzeny, 1955 1 Series, JW51, treegrower, cmayna, Gray_Ghost, 1 invisible),
161
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | I have a 55 - 2nd Series Chevy PU with the original gauge cluster and I have an 88' model Chevy fuel tank with sender unit. How do I get the original gauge to work with the newer model sender unit. The newer unit has a resistance of between 105 and about 20 or something like that when I check it with an ohm meter. "running on empty"!
Thanks! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I think the vendors sell 30 ohm sending units that will work with your tank. They're a universal sending unit. I believe your gauge is a 30 ohm gauge.
