4 members (Hotrod Lincoln, Deegs53, Jims46, Gray_Ghost), 256 guests, and 0 robots.
Topics128,088
Posts1,056,114
Members48,434
#461531 10/15/2008 2:23 AM
I ordered a knob for the side cowl vent handle for my '49 and can someone tell me what kind of clip I need to hold it on the handle? The knob is very loose on the handle so it must need something to hold it. Thanks!
Some good glue!
there's no clip or anything for it?
There isn't for any of the aftermarket vent knobs, side or center.
5min epoxy might do it but it would sure be a bear to get off if you ever had to.
Denny Graham
Sandwich,IL
Denny G
Sandwich, IL
Well glue/ epoxy it is then. Thanks guys!
If you epoxy it, and then need to get it off, just heat the lever with a small torch. The epoxy will let go, probably before the knob melts, if its plastic. Around 150 degrees is all.
Christopher
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Moderated by  ndkid275, Phak1
