Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (TUTS 59, Guitplayer, Jason Davies), 89 guests, and 5 robots.
Topics128,281
Posts1,058,476
Members48,490
#461999 10/16/2008 11:23 AM
Hi! All
I need a little help ID'ing a V8 Chevy Engine, here are the numbers I found on the engine.
Top of block front right side # 1094CZO
Other number on block # 152102656
Casting # GM3939180
I was told its a Chevy 331 CID out of a checker cab ??
It came out of a old street rod build back in the 60's
Thanks Phil
Can't find a CZO suffix, but CZD is a 262 cubic inch V-8 from a 1975 Monza. That's a pretty scarce variation of the small block engine.
try www.mortec.com They have lots of Chevy V8 number info, etc. Good luck.
Professional Novice
