2 members (59 fleet, KEVINSKI),
157
Mod | | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | I bought a pair a of supposedly '57 Chevy truck front leaf springs to replace the weak ones on my truck, and I'm having doubts looking at them.
It might be an optical illusion, but they don't appear to be the same as the ones on my truck. I was thinking they might be 3/4 ton or 1 ton springs, as I have a 1/2 ton.
Is there a positive way of identifying them? Length possibly?
I would post a picture but my camera recently went up in smoke.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The springs will be the same length, regardless of series. !/2 ton adn 3/4 ton are virtually identical, 1 ton as an extra leaf and a different spring clip configuartion. Here's the specs. Note at the bottom also shows lug torque specs as well.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | Wow!! Thanks for that link Bill!
Maybe the springs on the truck are just so fubar'd they don't even look the same.
I was hoping they weren't rear springs, so I'll have to measure them when I get home. Do you think GM measured eye-to-eye, or end to end?
Thanks again Bill!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I beleive it's measuerd eye-eye. The dimensions given are as installed.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | Okay, that might explain my measurements if it's taken as installed. I believe they are one ton springs.
Eye-to-Eye (center-to-center) = 41 1/2"
Total Length (end-to-end) = 43 1/2"
Width = 2"
# of Leaves (including the little one at the bottom) = 7
# of Clamps = 3
Clamp style = strap that wraps around | | |
