| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 34 Apprentice | | Apprentice Joined: Jun 2006 Posts: 34 | I think it's a 250ci engine, but when I bought plugs today for a 1971 250ci the plugs were the 5/8" plugs and the ones in there are the 13/16" plugs. Also the threads were twice as long on the bigger plugs.
On the head toward the back passenger side is 4487 toward the front passenger side is 4485 F 20.
On the block toward the back passenger side is CCON2 21 4 and in the middle passenger side is 3850817 0 then underneath that a GM then under that 20.
Thanks in advance,
-Jon
1955 Chevy Dumptruck 2003 Chevy 2500HD: Crewcab, Longbed, 2wd, 6-speed manual 2005 Pontiac GTO: 500hp and a transbraked TH400
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jon6.0, according to Inliners International, that is the block casting number for a 62-78 230 or 250, hope that helps. | | | | | Joined: Jun 2006 Posts: 34 Apprentice | | Apprentice Joined: Jun 2006 Posts: 34 | Hy jon6.0, according to Inliners International, that is the block casting number for a 62-78 230 or 250, hope that helps. Thanks! What can I look for to tell me if it's a 230 or 250?
