9 members (Gdads51, 52Carl, fonz8261, greenie-reddy, 2-Ton, Forty9, RoadsScholar, mk72, 1 invisible), 138 guests, and 1 robot.
Topics128,125
Posts1,056,343
Members48,441
#448385 09/03/2008 12:12 AM
Haven't found this question, yet.
Does anyone know of an aftermarket, or new original, or restored original water pump pulley that'll work on these old sixes (3/8" groove)? Can you still buy these anywhere?
Dave
Which engine/year? They are different.
Most of the GMC engines have the pulley pressed onto the water pump, so you could just get a new water pump. The later Chevy 235/261 engines are held on with the fan bolts and aren't reproduced, but there are lots of used ones available if you put a want ad in the Swap Meet section.
Paint & Body Shop moderator
You can also try ebay, there have been lots of pulleys for Chevys. Try a search for GMCs.
found it on ebay
Dave
I have a 54 on back style pulley from the shortened water pump that broke and went into the radiator on my 37,its free to anyone needing it. Jeff
