0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Haven't found this question, yet.
Does anyone know of an aftermarket, or new original, or restored original water pump pulley that'll work on these old sixes (3/8" groove)? Can you still buy these anywhere?
Dave
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Which engine/year? They are different.
Most of the GMC engines have the pulley pressed onto the water pump, so you could just get a new water pump. The later Chevy 235/261 engines are held on with the fan bolts and aren't reproduced, but there are lots of used ones available if you put a want ad in the Swap Meet section.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | You can also try ebay, there have been lots of pulleys for Chevys. Try a search for GMCs. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 |
Dave
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I have a 54 on back style pulley from the shortened water pump that broke and went into the radiator on my 37,its free to anyone needing it. Jeff | | |
