1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46170 06/10/2005 8:37 PM | Joined: Jun 2005 Posts: 5 Junior Member | | Junior Member Joined: Jun 2005 Posts: 5 | I just got my son (15 y/o) a 65 LB GMC to restore. It will need a lot of work. Would like to modernize anything that is fairly easy (front end, etc.) Any sources would be appreciated!
Thanks, MAG600 | | |
#46171 06/10/2005 11:34 PM | | Anonymous Unregistered | | Anonymous Unregistered | Welcome! The Front end is pretty solid on those trucks. The only reason you would want to change the front end would be for disc brakes which can be bought in the aftermarket for the original front end. Dual master cylinder if you keep the drums. Or power drums (a booster from a 67-70 chev). You might want to swap out the rearend for one with a lower gear ratio depending on what you have now. My 64 Chev has 4.10 gears in the back which limits my speed on the highway...might be good for your son  . Does it have a l6 or a v8? Good luck. AC | | |
#46172 06/11/2005 1:09 PM | Joined: Jun 2005 Posts: 5 Junior Member | | Junior Member Joined: Jun 2005 Posts: 5 | It has what appears to be a 70's 305 with 4 bbl Quad, HEI Dist. Just a few wires running the whole thing, pretty rough work on wiring. It has a 4 spd. but was orig. an auto. The trans and engine swap looks really good, thinking about going back to an auto.
#46173 06/12/2005 1:00 AM | | Anonymous Unregistered | | Anonymous Unregistered | Originally an auto? hmmm somehow an auto in a 65 GMC doesn't fit right in my mind...probably just me...If it has a V8 and so on, I would definantly look into a front end sway. Disc Brakes should stop your son....well at least better then drums. Bolt on IFS from 63-87 try that one for a rough idea of an easy (compared to the rest) disc swap. Good luck! | | |
