4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#461498 10/15/2008 1:15 AM
I have a 59 1-ton and i took the front fenders, headlite mounts, grill, etc apart to sandblast and repaint. I have found that there is alot of rubber gaskets between the fenders, and other metal parts that mount to the cab, are these factory gaskets or some kind of caulk?? they are not very stout, and fall apart very easily. If it's caulk what kind is it that you use to cushion between the metal parts??
panman #461546 10/15/2008 2:51 AM
any of the vendors have the sets of seals for those areas - the only thing you won't find is the piece that's stapled along the bottom of the inner fender to close the gap to the frame .... yours fell apart cuz they're 60 year old rubber grin
Flxible #461563 10/15/2008 3:12 AM
GM called them anti squeak. You should get a Factory Assembly Manual; these items are detailed there.
~Jim
Jim & Caroline
