| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | I have a 59 1-ton and i took the front fenders, headlite mounts, grill, etc apart to sandblast and repaint. I have found that there is alot of rubber gaskets between the fenders, and other metal parts that mount to the cab, are these factory gaskets or some kind of caulk?? they are not very stout, and fall apart very easily. If it's caulk what kind is it that you use to cushion between the metal parts?? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | any of the vendors have the sets of seals for those areas - the only thing you won't find is the piece that's stapled along the bottom of the inner fender to close the gap to the frame .... yours fell apart cuz they're 60 year old rubber  Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | GM called them anti squeak. You should get a Factory Assembly Manual; these items are detailed there.
~Jim
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
