10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46115 06/09/2005 4:38 PM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Does anybody have any a-z tips on changing the fluid in the transmission and differential on a '50 3100? The service manual doesn't even address how to do this, only that it needs to be done. I can't find anything on this site that addresses it in detail.
I guess my biggest question/concern is, if there's only one port (drain/filler plug) on the differential, how can you drain it and fill it through one hole? It defies physical logic.
Thanks! | | |
#46117 06/09/2005 5:49 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Try taking the lower bolt out of the differential cover.Should drain,the hole goes all the way through. If not,you'll have to remove the cover. Make sure to put some thread sealer on the bolt when you replace it. | | |
#46118 06/09/2005 8:45 PM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Thanks. How about tips on changing the transmission gear oil? | | |
#46119 06/09/2005 8:57 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Mine has a drain plug and a fill plug. There is also a small plug on top of the trans at the rear to add lubricant to the u-joint after removing the trans/clutch/u-joint. I use Quaker State in a long bottle that pours in nicely if you hold the end right up against the floorboards. | | |
#46120 06/09/2005 9:00 PM | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | You can see my methods for changing tranny and pumpkin gear oil here: Gear Oil Change You may notice that I am currently using Synthetic Gear Oil in the tranny and standard gear oil in the differential. That is because my rear end leaks some (not a personal problem  ) and the tranny doesn't. Synthetic Gear Oil may leak out of places where regular gear oil won't. | | |
#46121 06/09/2005 10:00 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Laroke; My old manual says 50 wt motor oil in my 3 speed tranny. Used that and it still whines. What brand of synthetic tranny oil you using and where did you get it? I read somewhere that you shouldn't use hypoid oil in the tranny because of the brass. if you were to use regular tranny oil, do they make a non-hypoid oil which is readily available at the local Parts depots? If so, same weight? Thanks in advance. | | |
#46122 06/09/2005 10:41 PM | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | I am using Valvoline in the 75-140 wt., Geezer. Here's the product spec Valvoline Full Synthetic Gear Oil Don't know enuf to know if I'm causing damage to the tranny or not with this stuff. Maybe someone who knows more will jump into the thread. | | |
#46123 06/09/2005 10:51 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I'm using the same gear oil in both the tranny and the diff. Quaker State 80-90W and the label specifies it is good for manual trannys and differentials. | | |
#46124 06/09/2005 10:51 PM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | GM has a synthetic transmission and differential oil. Used the special non slip differential oil in a Nissan manual transmission and avoided taking it out for an overhaul. Fixed up a 'sticking' shift into second gear. Also, this product might be fine. http://www.desertrat.com/redline_oil/redline.htm cheers, George | | |
#46125 06/09/2005 11:23 PM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | | | |
#46126 06/11/2005 3:06 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Mystic JT 6 is the best gear lube available it should be available at most parts stores.this stuff will keep a tranny or differential alive for 1,000,000 plus miles in class 8 vehicles( BIG TRUCKS)i use it exclusively in all standard trannies and differentials. | | |
