1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46076 06/08/2005 5:55 PM | Joined: Apr 2005 Posts: 16 Junior Member | | Junior Member Joined: Apr 2005 Posts: 16 | Does anyone know of a somewhat "foolproof" way to physically identify a 292 six, from a 194,230, or 250 eng? It would be great when at the wreckers to open a hood and say "nope" and move on to the next one, without wasting a lot of time. Also what year trucks are they commonly found in? Thanks, JD
unless your the lead dog, the view never changes!
#46077 06/08/2005 6:15 PM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | fuel pump located behind passenger side mount on 292 and is in front of mount on 194,230,250 also the side covers are taller on 292, trucks, busses, stepvans from mid sixties to late eighties | | |
#46079 06/08/2005 9:06 PM | | Anonymous Unregistered | | Anonymous Unregistered | Yup, 66/Stepside has it. The quickest, easiest thing to look for is the location of that fuel pump. The fuel pump and the right side motor mount swap positions between the 292 and the smaller sixes. If the pump is in the middle of the block, it's a 292. | | |
#46080 06/09/2005 4:03 AM | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | The 292 passenger side covers are 6" tall and the others are 4". The 292 block deck height is about 2" taller. See the other posts for fuel pump, distrib. and mount location info.
Just my thoughts, Walt | | |
#46081 06/09/2005 5:30 AM | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | "The 292 passenger side covers are 6" tall and the others are 4"."
This is incredibly obvious once you've seen it. | | |
