0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | has anybody out there in boltland heard of converting stock gearing box that uses grease to use steering fluid. I heard about this as one of those upgrades without changing appearance but i didnt get any info on how to go about it. Mine is a 36 and that is the same year i heard this mentioned about. Thank you  | | | | | Joined: Aug 2008 Posts: 38 'Bolter | | 'Bolter Joined: Aug 2008 Posts: 38 | I can't really see any advantage of putting "steering fluid" in an early box. Originally most of the boxes had 90wt gear oil in them but got packed with grease when they leaked the gear oil out as fast as you could put it in.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | They make a special lube for the old boxes. However, they should be cleaned and resealed. I personally put gear lube in mine. It worked for 50 or more years. | | |
