| | | Forums66 Topics128,049 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I got a gallon of that star fire paint, metalic. But I think I messed up, I have always wet sanded and rubbed out my mess ups and or dog hairs and bugs. But I read today that you cant rub out metalic paints, wont work and will not look right. Is that right? If so I need to get a straight collor, thanks. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I'm not sure about modern metallics but in my day it depended on how the paint was applied. If it was done right, sanding would change the color because the metallic would settle under the pigment - paint has three components: vehicle, binder and pigment. Metallics add microscopic pieces of bright flakes of metal or something else. Sanding would thin out the pigment layer and consequently the microscopic specs of metallic would appear lighter.
We always put a lot of clear over metallics and just wet sanded and buffed that. It's okay to scuff the surface, but avoid deep sanding.
At least that's my experience. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The amount of thinner used can change the color of a metallic paint as well. Use your metallic if you wish but put a couple of coats of clear over it if you want to sand & buff it.
