2 members (Steelonsteel, Hotrod Lincoln), 136 guests, and 4 robots.
Topics128,109
Posts1,056,261
Members48,439
I've just about had it with the two Rochesters BC's sitting on the Offy intake on my 250. Is there an easy way to upgrade to a more modern setup like post '64 monojets? Where do you buy them and the necessary linkage to run dual carbs? Can one purchase new BC's at a reasonable price? Where? Can anyone point me toward any info/articles dealing with this? I know, lot's of questions and I thank you in advance for any help.
Do a search at this web site. There are many alternatives.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Here you go: Do a search under all open topics "carbs for offy". You will get 25 responses. Hope this helps.
Riding in the Passing Lane
The monojets came out in 68. I think that would be the best bet. I,ve had good luck with model B,s but have never run more than one at a time.You will probably have to fabricate linkage. smile
1972 Chevy c10 Cheyenne Super
52pu -- now that's MY kind of response.
We are trying to get folks to use that Google search. Even I've been using it to find stuff when I forget where I put them!!
Tanks!
Peg
~ One of many.
Junior Member
Junior Member
Go to Tom Langdon's Stovebolt Engine link below.
He has carbs as low as $65.
Manifolds, linkage, etc.
www.stoveboltengineco.com/acartpro/category.asp?catcode=33
Just my Thoughts,
Walt
You can buy rebuilt monojets from JC Whitney CHEAP CHEAP CHEAP!
Boo
We don't need no stinking V-8s!!
How about Carter YF models? Doug
Quote
How about Carter YF
Yes JC Whitney sells those cheap, but you have to order by year and model of vehicle. A lot of guys around here can tell you what rigs came with the yf carbs.
Boo
Can someone help out with the year and models that came with the Carter YF?
George
