3 members (Cosmo, Wayne67vert, Bills Auto Works), 60 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#460105 10/10/2008 11:48 AM
I just bought a 49 pickup with 216 engine and no distributor. The engine looks good, has no stuck valves, and has compression. However, a lot of wires to it are cut, and the mounting bolts are out. I am unsure whether someone was pulling the motor to replace it, or pulling a good motor to put in another truck. I'd like to see if this engine runs but I don't have a distributor for it, and hate to buy one if the engine is not any good. I do have a 235 distributor on a good '61 engine (destined for another truck). I've read in the archives not to use the 235 dist without switching gears (which I don't have). I see LMC lists the same distributor for both 216 and 235. So, can I use my 235 distributor in the 216? I'd like to use the 235 dist, get the 216 running for a few minutes, see if it knocks or smokes excessively, and if it appears that it is fixable get a distributor for it. Will it work? Thanks for any help!
Josh
Don't know if you can put the 235 distributor in the 216. I do know that you don't want the 216 distributor in the 235 because the 216 distributor drive gear is steel and the 235 gear is alloy or bronze, so therefore I would think that the 235 distributor should or might work in the 216. Just be aware that the Caps and Rotors are different between them.
I agree. Give the 235 dist. a shot. I've switched dizzys in and out of 216,235 even my 261 for a quicky with no problems. I see your in SE Pa and I'm in South Jersey, so if it comes to it maybe I can scrounge up a dist. for you. It may not have all the parts,but they're pretty simple to rebuild.
Drew
The Chev parts book lists the 235 distributor as a replacement for 216s, so it will surly be fine for a test run.
My Blog
Thanks guys! I think it should work at least for a test run. I bought this old truck for parts for my '53, but I think its just too nice to take apart. Tomorow we'll find out if it runs as good as it looks!
Josh
I have one I'll send you out of a 235 if you wanna pay shipping from AZ.
