| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 54 | I just bought a 49 pickup with 216 engine and no distributor. The engine looks good, has no stuck valves, and has compression. However, a lot of wires to it are cut, and the mounting bolts are out. I am unsure whether someone was pulling the motor to replace it, or pulling a good motor to put in another truck. I'd like to see if this engine runs but I don't have a distributor for it, and hate to buy one if the engine is not any good. I do have a 235 distributor on a good '61 engine (destined for another truck). I've read in the archives not to use the 235 dist without switching gears (which I don't have). I see LMC lists the same distributor for both 216 and 235. So, can I use my 235 distributor in the 216? I'd like to use the 235 dist, get the 216 running for a few minutes, see if it knocks or smokes excessively, and if it appears that it is fixable get a distributor for it. Will it work? Thanks for any help! Josh | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Don't know if you can put the 235 distributor in the 216. I do know that you don't want the 216 distributor in the 235 because the 216 distributor drive gear is steel and the 235 gear is alloy or bronze, so therefore I would think that the 235 distributor should or might work in the 216. Just be aware that the Caps and Rotors are different between them. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I agree. Give the 235 dist. a shot. I've switched dizzys in and out of 216,235 even my 261 for a quicky with no problems. I see your in SE Pa and I'm in South Jersey, so if it comes to it maybe I can scrounge up a dist. for you. It may not have all the parts,but they're pretty simple to rebuild.
Drew
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The Chev parts book lists the 235 distributor as a replacement for 216s, so it will surly be fine for a test run.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2008 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 54 | Thanks guys! I think it should work at least for a test run. I bought this old truck for parts for my '53, but I think its just too nice to take apart. Tomorow we'll find out if it runs as good as it looks! Josh | | | | | Joined: Sep 2006 Posts: 8 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 8 | I have one I'll send you out of a 235 if you wanna pay shipping from AZ. | | |
