| | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 6 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 6 | I have 2 3/4 ton 4x4 Suburbans. I want to know what one I should mount my heavy LEO DOT plow on. 1989 4x4 350 FI 4 speed manual, lockouts or a good condition 1974 Cheyanne Super with a 350 turbo 350 and posi rear. Both are full time 4x4s. I was warned the 74 transfer case chain will jump right away..... | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I would say the 1989 4x4 350 FI 4 speed manual. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Either would be fine, however the '74 will have the stronger axles as well as a stronger t-case. As long as the chain isn't sloppy, there isn't anything to worry about. BTW, the '89, if original, should not be full time. It should have the NP208 part time t-case with the planetary low range. Also, the full time case (not used after '79) was not available with a manual trans, with the exeption of the '74-mid-'75 3/4 ton pickup, very rare.
Bill Burmeister | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | You may be right. The older one would have stronger steel, and would likely be more durable. I based my choice on the manual transmission - I figured it would be better in the snow, and more durable than the automatic. I've never plowed snow before, though. Maybe Scott(48bigtrucks), or someone else, will be able to answer with a more educated answer than mine. | | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i've plowed some snow not a whole lot but some and choice on trans is kinda a toss up the auto is nice cause then your not constantly clutching, but with the Auto from what i'm told its best to put the shifter in First and not drive
Nate | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | With the automatic, you get the advantage of the torque converter, plus less likely to burn up a clutch. I only know of 2 guys around here that plow with a stick, one has a mutt truck peiced together out of sevral years and styles (short bed w/ 3/4 ton axles, a '74 drivetrain w/full time 'case and 4 speed), the other uses a '42 GMC 6x6 with a 302 and a 12 ft blade. As to strenght, I was more referring to the ealier tuck using a Dana 44 front axle and the 14 bolt full foater in the back. The later 'Burb would more likely have the 10 bolt fron with the 14 bolt semi-float in the back. The older truck has heavier capacity axles. In either case, the transfer cases are chain drive, using a virtually identical chain, although I seem to recall that the 203 actually has a wider chain. It also has a stronger low range case. If you want an even stronger setup, use the NP205 gear drive 'case with a 203 low range housing adapted to it. I beleive Advance Adapters makes the kit. That will allow for not only a super strong gear drive 'case, but also a double low range. I would not use that with semi-float axles, though.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | As someone who has sold, installed and serviced hundreds if not thousands of snow plow I can definately tell you all my customers wanted AT. Clutches are a PIA for this type of work. Use the newer truck and change to an atomatic. | | | | | Joined: Oct 2008 Posts: 6 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 6 | Belive it or not the 89 is a full time 4 speed with warn lockouts. I have been told it is a really rare combo! Thanks for all the help guys...... | | | | | Joined: Oct 2008 Posts: 6 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 6 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Unless the 'case has been changed out to a 203, it's a part time 208. GM did market it as a shift on the fly 4 wheel drive, marketed as the "Insta-Trak" system. It uses a fully syncronized shift mechanism and auto locking hubs. You mentionit's got Warn lockouts, a popular swap when the auto lockers fail, basically making it a traditional part time system. The true full time 4x4s stopped production in '79. A 'Burb with a manual trans is unusual, though, as most were automatics.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Plow with the Automatic. Plowing with a stick sucks and is hard on the clutch.
