8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 24 | whats the best way to get the guts out of the door on a 49 gmc? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a GMC maintenance manual?
If the door is still on the truck, I'd leave it there until all parts are removed. Remove the cardboard panel from the door and remove the metal cover on the lower hinge side of the door.
If you are intending to remove everything, start with the window and then the window mechanism. Then, the door latch control rod/assembly (or, I think you could remove this first).
One bolt at time - label and bag all bolts/nuts/washers.
The GMC Maintenance Manual has instructions for removing the window, window regulator, and the door lock assembly.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There is a cab manual available from some of the vendors that has a bit more information then the shop manual I think they are 6-7$. Not a bad investment as you want to get the doors right or they will bug you everytime you get in or out of your truck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The GMC Maintenance Manual has quite adequate instructions on how to remove parts from the door (with pictures). The Chevrolet Truck Shop Manual contains almost the same information. Hanging the doors and adjusting the door latches/catches is another more interesting undertaking.  | | |
