| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45932 06/06/2005 7:48 PM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | I tried a search, but had no luck, so I'm sorry if this is on here somewhere. I'm looking for a site to check my block numbers. I'm having problems with the main bearings. It's a '58 235. The rear main journal tab is on the opposite side as the front 3. I've double checked the part # for the bearings and it appears to be right. Thanks in advance.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
#45933 06/06/2005 7:55 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | There is a link on the Inliner\'s site That should tell you what you need.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45934 06/06/2005 10:55 PM | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 |
