5 members (rick46ia, elhippie64, Peggy M, JW51, 1955firstseries), 66 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#45932 06/06/2005 7:48 PM
I tried a search, but had no luck, so I'm sorry if this is on here somewhere. I'm looking for a site to check my block numbers. I'm having problems with the main bearings. It's a '58 235. The rear main journal tab is on the opposite side as the front 3. I've double checked the part # for the bearings and it appears to be right. Thanks in advance.
'54 3100-235-T5 trans-12 bolt 3:31
'68 Impala 307/350
'78 Sportster/Original owner
#45933 06/06/2005 7:55 PM
8
8 Offline
There is a link on the Inliner\'s site That should tell you what you need.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45934 06/06/2005 10:55 PM
Thanks fab51
'68 Impala 307/350
