| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 28 Apprentice | | Apprentice Joined: Jun 2008 Posts: 28 | Hi, I'm cleaning up my speedometer gear reducer out of my 2 ton. It looks like the larger screw on the top is for grease, what kind should I use? It looks like the diaphram is in good shape, though I found the whole unit disconnected on the floor. The vacuum line was rotten. Hopefully I can replace the line and it will work. I love this site, I get lots of enjoyment out of what you all are doing. Thanks. | | | | | Joined: Jun 2008 Posts: 28 Apprentice | | Apprentice Joined: Jun 2008 Posts: 28 | | | | | | Joined: Jun 2008 Posts: 28 Apprentice | | Apprentice Joined: Jun 2008 Posts: 28 | I ended up just putting some 90wt gear oil in through the slotted head screw on top while rotating the square drive key. It was stuck at first, but after turning it a while it turns easily. It will be nice to have a working speedo. | | |
