0 members (), 115 guests, and 1 robot.
Topics128,113
Posts1,056,619
Members48,450
Apprentice
Apprentice
Guys, I tried SEARCH, but page after page took me off in different directions. Here's my problem: I got a set of new door latches from the guy that I bought my '51 Chev COE off of. Don't know where they came from, but today I installed them. The driver side latch works part of the time (after a lot of 'adjusting') and the passenger side doesn't work at all. I'll buy another set, but I don't want the same junk.
Any suggestions as to QUALITY door latches for my truck? Thanks much.
~Bruce
Y
Y Offline
I've run into the same problem, the first one I ordered wouldn't work at all and the replacement wasn't much better. I think they all come from china. I would suggest trying to rebuild an original. If your patient, you can take them apart and file new stops and peen the shafts to tighten them up. Hit the swap meets and maybe you can find something better than what you got. Last resort just check with the venders and see if they will bench test one before they ship it to you. Just my 2$.
I have recieved quality parts from two places in Calif.
1 The Truck and Car Shop in Orange Ca.
2 The Brothers Trucks in Corona Ca.
Both these companys will refund your money or exchange out the bad parts for you. They are exellent to deal with and good Tech Support people. Good Luck. Could it possibaly be bad Striker plates? I had that problem and used both new.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don't waste your time or money on "new" door latches from overseas. Use originals, repair them as needed... it's well worth it.
This is off topic, but I had the same problem using the search function. Click on, and read the advanced search options. It has made my life here a LOT easier. 8-)
Apprentice
Apprentice
Thanks, all of you. I've got one working pretty well now, after a little filing & a lot of greasing. I feel confident that I can get the other functional with enough work. You're right- it's Chinese junk. Shame the originals were missing so many springs, etc. Don, I'm noting your quality vendors. Thank you.
(Advanced Search Options. Got it! Thanks, Jimmie D!)
~Bruce
When I was looking for the same thing, my Classic Truck parts supplier said he doesn't carry the repros anymore because they are no good. I waited a long time and bought some NOS original GM locks on Ebay.
1951 1 Ton Completed
