3 members (66flea, BC59, dt235sd), 184 guests, and 3 robots.
Topics128,087
Posts1,056,106
Members48,434
I did not have a camera for pics,but I saw an AD 1/2 ton with power steering, it obviously worked, but I wasn't sure if this is a good idea, looking for criticism, constructive or otherwise.
Here's what he did:
1. Turned his axle around so the tie rod is now in front.
2. Took a power steering gear, pitman arm, steering stabilizer and the drag link/tie rod assembly from a older full size jeep wagoneer and put it in place on the AD.
3. Cut and bushed his steering shaft with one U-joint to the saginaw box.
4. Had front end aligned.
Now he has front cross steering.
I think a locator bar or sway bar would have been a good idea to keep the axle in check, but he said it worked great.
Chris
Why do you need power steering?
Tony, should have expected that. Nowhere does it say that I need or even want power steering. Okay when I am towing the boat (26 footer 6000+ lbs with triple axle trailer) and backing around the launch, I want power steering.
I don't have it on the my jeep, coupe or 1 ton.
Purely hypothetical discussion of the aforementioned method and this would also work with a manual box to reduce bumpsteer I think.
Chris
Ok,you answered my question.To me,less is better,manual steering builds muscles!!!
AD trucks don't suffer from bump steer or steering wheel kickback unless the suspension parts are worn.
I heard that placing the tie rod in front may help reduce tie rod flex when adding brakes with increased stopping,like discs.
What does that do to the kingpin angle?Wouldn't you lose all your rake? Of course I guess you could shim it back in with a couple of wedges,huh?
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Aint the idea of needing power steering for me.It updates the truck a little and makes it a hell of a lot more fun to drive.I dont need an old 55 Chevy pickup either,but I sure have a lot of fun with it power steering,power disc brakes,V/8,automatic,and all.As fpor building muscle,I dont think so.Gotta go up to the gym and pump a little iron to do that.
Exactly,you don't really want an old truck,you just want the old truck look.That's ok,it's yours to do as you want.
