3 members (Ponchogl, baldeagle, elhippie64), 67 guests, and 11 robots.
Topics128,020
Posts1,055,345
Members48,420
#45890 06/05/2005 4:09 AM
Apprentice
Apprentice
i would like to keep my stock steering in the 52 gmc pickup 3/4 ton however when i attempted to put a small block in the steering shaft had to be taken out not a big deal but what options do i have to avoid the manifold while keeping the steering stock i suppose is there a vehicle out there i could find as a doner to fix this would like to hear from ya all
This is a natural point to install a PS kit. You can keep the stock steering wheel and mast, and also the stock straight axle. If you take that route, you will want to know about the correct drive pulley for youe setup too.
1951 1 Ton Completed
DJ Offline
This has been done many time. The steering box needs to be spaced over 1 1/4 inches. Slot the holes in the dash also. It has no ill affects on steering and is allmost undetected. Been done since the 265 came out in 55.
