| | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I finished replacing the inner cowl on the right side today. Then I removed the floor pan. I have a replacement that goes from about 6" up the toe board back to the seat base. This is a 52' 3100. When I removed the old pan there was an angle brace that ran along the side of the transmission cover and welded where toh old toe board met the floor. It fell apart. Is this part available or should I just get a piece of angle and drill and tap for the cover bolts. | | |
