7 members (Rusty Rod, TUTS 59, 55shaker, RLB, WICruiser, Gdads51, Jay R), 102 guests, and 3 robots.
Topics128,054
Posts1,055,782
#458524 10/04/2008 10:58 PM
Thanks to Wrench Fetcher and Shop Shark for the timely info re: Headlights. Turns out my switch was OK, I wired it as per the "book" and came to realize the contacts in hand did not match the book. After a quick swap it checked out and I went onto the next Prob. The parts guru at the counter has insisted for the past week that the horizontal terminal on a 12v headlite was the negative.(I am fabbing my own harnesses) Well I kept getting 12v back feed. I went for the 9 O'clock position as neg. and presto, back feed gone and bright lights! Thanks again Fellas!
3B Offline
Hy tools94, actually your thanks should go to "3B" and "coilover", shop shark and wrench fetcher are titles you are given based on the number of posts you have made. Glad we were able to help.
3B #458730 10/05/2008 11:36 PM
Jim & Caroline
