2 members (baldeagle, jmoore), 155 guests, and 0 robots.
Topics128,037
Posts1,055,469
Members48,424
#458691 10/05/2008 8:23 PM
headscratchAre the felt packing grease seals for the front hubs of a 1.5 Ton available anywhere? Everything I have seen are replacement grease seals. Are there any preferances on which are better?
Kevin smile
I'ld go with the lip seals, they hold water out better in my opinion,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Ive replaced the seals in my COE with felt and they worked great, both front and rear. I bought discs of it at McMaster Carr and cut to size. A circle cutter for a drill works wonders. I had to use felt as the seal was inside a lipped flange on the truck. No way to use a standard oil seal there.
Recently I went through both front and rear axles and pulled the lipped portions off and plan on using newer nitrile seals for all the hubs, because my rear hubs were made to run grease and there was a seal which rode on the axle nut to keep the oil from transferring into the hubs. Up until recently they worked great, but I noticed a small stain inside the tire and pulled it apart to find that the outer seal had failed (due to pitting on the axle nut) and that fluid had gone through the hub and past the felt seal contaminating the brake linings.
An expensive mistake, but live and learn.
Good luck, Jeff
My 1953 Chevrolet
1947.1 Gallery
Thanks Scott and Jeff. thumbs_up McMaster is a good site.
I have also made the felt seals, for front and rear axles on a 1929 Hudson car.
Buy the felt from McMaster Carr, and also a gasket cutter from them. It has two blades, one cuts the inside diameter, and one the outside, all at the same time. Sharpen the blades as sharp as you can get them, tack the felt to a board, and carefully cut out the felt donuts. The circle cutter is not supposed to be used in the drill press, but I ran it slow with a slack belt, worked great, just don't stick your fingers in there.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
