1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 14 New Guy | | New Guy Joined: Mar 2005 Posts: 14 |  Here I am, Novice to the world of trucks. I have a running 55 chevy one ton with a 6 cyl. Runs, but smokes some. More than I would want from a respectable truck. Smokes more when cold. Smokes less when warm, but still continues to smoke. No big black smoke, but I don't I will ever have a problem with misquotoes either. Suggestions I have received is maybe a valve job. Is that very expensive? Suggestions would be appreciated. Thanks, WoodChips
WoodChips
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | WoodChips,
My bet is you are describing worn rings not valves. I think your engine needs a rebuild. A valve job would not cure the problem, it could make it worse. Have you taken compression readings yet?
Stuart | | |
