5 members (dt235sd, klhansen, 2-Ton, 52GMC35424JD, Hotrod Lincoln), 79 guests, and 3 robots.
Topics128,049
Posts1,055,665
#458404 10/04/2008 7:21 AM
Has anyone wired the 4L60E to be used behind a carbed engine? How did it work out? Painless offers a stand alone system and I'd bet Ron Francis does but I'd like a few comments before jumping in. Thanks.
Evan
coilover #458654 10/05/2008 3:50 PM
Just a suggestion: You may want to check out "Street & Performance" out of Arkansas. Guys around here that are running late model power plants & transmissions with all the sensors and such in streetrods use S&P to modify the computer and wiring harnesses.
beltfed #459358 10/07/2008 11:39 PM
Check this out. There are several pages that tell how to make your transmission work without a fancy harness.
http://www.geocities.com/crosley_az/lockup1.htm
