| | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | Thanks to Wrench Fetcher and Shop Shark for the timely info re: Headlights. Turns out my switch was OK, I wired it as per the "book" and came to realize the contacts in hand did not match the book. After a quick swap it checked out and I went onto the next Prob. The parts guru at the counter has insisted for the past week that the horizontal terminal on a 12v headlite was the negative.(I am fabbing my own harnesses) Well I kept getting 12v back feed. I went for the 9 O'clock position as neg. and presto, back feed gone and bright lights! Thanks again Fellas! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tools94, actually your thanks should go to "3B" and "coilover", shop shark and wrench fetcher are titles you are given based on the number of posts you have made. Glad we were able to help. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
