4 members (2-Ton, Ponchogl, Robert Crandall, 1 invisible), 89 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#458341 10/04/2008 1:55 AM
Im using a abrasive pad on my side grinder to remove the rust and smooth down the surface. A guy told me yesterday that i need to get down to the metal until it shines, is this true,
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
If the metal is still black or discolored, it still has rust on it. Shinny sheet metal is clean sheet metal.
If you want to remove all the corrosion you have to use one of several methods to do so, but there are products on the market that you can apply and paint over, like POR, Eastwoods Rust Converter and Encapsulator or Ospho to name some.
Under normal climate conditions, rust needs moisture and air to grow. Deprive it of one of those and it stops spreading. The problem is that you must completely stop one or both and that may not be as easy as it sounds.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
You may want to try this method called electrolytic derusting. It seems to be working well for me. Do a search in the forums or use this link.
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
The CPA, never under estimate the value;
especially when he's driving an old Chevy truck!
1947 Chevy 1/2-Ton Advance Design in the Gallery
1951 Chevrolet 3100
