10 members (MickeyP, 32Fordpuchoptop, Steelonsteel, Hotrod Lincoln, DennisM, Tronman, JW51, Otto Skorzeny, Charles in CA, 1 invisible),
104
Mod | | | Forums66 Topics128,042 Posts1,055,505 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45825 06/03/2005 4:28 AM | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | I recently picked up a '50 chevy 3/4 ton truck. I don't know what engine size these came with. Is it a 216 or 235 ?? How can I viually see the difference. Whatever it is...it runs pretty good. Thanks
1970 bbc Monte carlo 1950 chevy truck
#45826 06/03/2005 4:43 AM | Joined: Jul 2004 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 60 | The 216 Has a tin Cover Over the Spark Plugs and Push rods. where as the 235 only has a cover over the Push rods. Thats the main way I can tell the difference. I think that a 3/4 ton has a 235 But Im not sure. This is my minorly educated answer.  Jess
1951 3100
#45827 06/03/2005 4:46 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Give us an engine casting number. It's located just in front of the distributor (right side) above the oil pan rail. A head casting number would also help. It's located on the top of the head next to the valve cover (left side) above the second exhaust port.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#45828 06/03/2005 1:26 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | The 235 was optional equipment on 1-1/2 & 2 ton trucks. Also, in 1950, the 235 was identical in looks to the 216 and was also a low pressure, babbit bearing engine. The numbers are really the only way to be certain.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45829 06/03/2005 1:40 PM | Joined: May 2005 Posts: 4 Junior Member | | Junior Member Joined: May 2005 Posts: 4 | I will get those casting #'s. The truck should be getting dropped off here this weekend. As soon as I can get the numbers I will post them. Thanks, I appreciate the help.
