0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#45825 06/03/2005 4:28 AM
Junior Member
Junior Member
I recently picked up a '50 chevy 3/4 ton truck. I don't know what engine size these came with. Is it a 216 or 235 ?? How can I viually see the difference. Whatever it is...it runs pretty good. Thanks
1970 bbc Monte carlo
1950 chevy truck
#45826 06/03/2005 4:43 AM
The 216 Has a tin Cover Over the Spark Plugs and Push rods. where as the 235 only has a cover over the Push rods. Thats the main way I can tell the difference. I think that a 3/4 ton has a 235 But Im not sure. This is my minorly educated answer. smile Jess
1951 3100
#45827 06/03/2005 4:46 AM
smile
Give us an engine casting number. It's located just in front of the distributor (right side) above the oil pan rail.
A head casting number would also help. It's located on the top of the head next to the valve cover (left side) above the second exhaust port.
#45828 06/03/2005 1:26 PM
8
8 Offline
The 235 was optional equipment on 1-1/2 & 2 ton trucks. Also, in 1950, the 235 was identical in looks to the 216 and was also a low pressure, babbit bearing engine. The numbers are really the only way to be certain.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45829 06/03/2005 1:40 PM
Junior Member
Junior Member
I will get those casting #'s. The truck should be getting dropped off here this weekend. As soon as I can get the numbers I will post them. Thanks, I appreciate the help.
1950 chevy truck
