| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | Is a conversion from Huck to Bendix brake system in the realm of possibility on a '49 3100 rear? If so, what year donors should I be looking at and what level of grief can I expect? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive never done it but it should be straight forward. 51-54 parts will bolt right up. Probably 55-59 also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | I'll start looking for a possible donor, I had a '65 rear disassembled and it looked promising, but there was a slight indentation in the original backing plates and the donors were flat. All said and done it looked fine, except that the axles became 1/2 inch too short and the c-clips would not engage. It was a lot of wasted time but an education none the less. | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | I'm in the middle of this swap and found that the easiset way is to find a later model AD rearend. The Bendix brakes were first used on 53 and later I believe. I have a 54 I bought from Banter's salvage yard in Hudson Florida. Unfortunately I didn't know there is also a standard transmission rearend and an automatic made for the 54 year and guess what. I ended up with the one for an automatic and the torque tube is several inches shorter than one for a standard trans. I'll be changing over my 49 T-tube and carrier and using the 54 banjo housing with the bendix brake backing plates.
Still trying to get ole Betsy back on the road.
| | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | I had a 54 rear w/bendix on the project when I rec'd it,it had no driveshaft with it. So I went back to the original w/torque tube and re-vamped the pumpkin w/3:55 gears from Patrick's and had everything all sweet and THEN looked at the Huck system. talk about pre-planning and scoping things out. But, at least I have 6 lugs on all four wheels! | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 1/2 ton Bendix started in 1951.
Fred 52 3600 69 C-10
