| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45816 06/02/2005 9:24 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | Have any of you Carter guys had any leaks at the throttle plate shaft? I have that problem with my Rotchesters and wondered if I should expect the same from the Carters. How did all this sawdust get under the hood? | | |
#45817 06/03/2005 5:14 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I haven't noticed any from mine, but I've only had it for a few weeks.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45818 06/03/2005 9:12 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I had some leaks on my 2100S but it was an older rebuild that had been sittin on the shelf for a few years. put a new kit in it and no leaks.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#45819 06/03/2005 9:53 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | Blue, where was it leaking from? How did all this sawdust get under the hood? | | |
#45820 06/04/2005 1:18 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 |
Blue 50
