4 members (Otto Skorzeny, Materman, mason86, GRNHydra), 100 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#45809 06/02/2005 9:22 PM
For those of you who have made the switch to Carter carbs from Rochesters, what kind of gas mileage improvements have you seen?
How did all this sawdust get under the hood?
#45810 06/03/2005 5:16 PM
8
8 Offline
I've always heard of this imporvement, but when I made my swap, it seems like the mileage had actually decreased. I don't have any hard numbers to back it up, though. One problem may be that I had a couple of parts carbs, and I found the largest jet to install. It has vastly improved the performance, though.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#45811 06/03/2005 9:10 PM
I heard the same thing about performance....and it's true with the 2100S I have recently installed, my truck definitly runs better with it. I think my mileage has gone down same as fab51. I'm getting ready to adjust valves and check timing again...maybe that will help.
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#45812 06/03/2005 9:55 PM
A drop in mileage is disappointing. I am hoping that the cure for the leaky Rochesters will increase my mileage.
#45813 06/04/2005 10:52 PM
The two Carter/Webbers on my 261 seem to have increased the fuel mileage from 13 to 15 (approx). Only have about 250 miles with new engine and carbs and Fenton headers. Will get back when I put another 250 on it.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#45814 06/04/2005 11:02 PM
Hey 1212, are you going to Traders village next week-end,,,,,Fred
Redryder pix
My Hotrod
#45815 06/05/2005 4:11 AM
When I went from 2 1bbl Rochesters to 2 1bbl Carters on a '58 235 with Fenton headers, Mallory ignition and dual exhausts my gas mileage went from @11MPG to 15 MPG around town and about 17 MPG on the highway. I also installed a fuel pressure regulator to bring the fuel pressure down to about 4 1/2 to 5 lbs.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
