5 members (Gdads51, Wayne67vert, 52Carl, SmalltownTRKGuy, 1 invisible), 121 guests, and 0 robots.
Topics128,050
Posts1,055,632
#457837 10/02/2008 4:59 AM
The HEI distributor is new to me. In trying to install my wiring and I am instructed to run a yellow wire if I have a points distributor. My distributor is an HEI. Does that mean it has points. It is easier to ask you guys rather than popping the cap.
~Jim
HEI doesn't have points.
Question: Is your new wiring harness 'store bought'? If so, are the instructions for a HEI wiring installation left out? If the answers to the above questions are yes, who built your wiring harness? Thanks
See, that was easy and I didn't have to pop the cap and guess. Another Bolt success in the never ending battle against confusion.
~Jim
The kit is a Highway 22 from American Wire. Yes it has instructions but expects you to know if your distributor has points or not. If it has points there is an additional step to take.
~Jim
Makes sense to me. The HEI wants to see straight 12V all the time but the points only see 12V during startup then they see something like 9V through a ballast resistor the rest of the time.
So that's what that "hot" resistor does on my 2N besides just sitting there waiting for me to grab hold of it.
~Jim
Waldo 53...I have a Mallory small cap HEI on my 250ci. The instructions do call for a ballast resistor. My old OEM HEI did not have a ballast resistor or resistance wire that I can remember. So I would think it best to say some HEI's require a resistor, others not. And yes 'Big Chevy 3600', the resistor drops the voltage during engine run. It is bypassed at start up.
make sure and there have been many discussion here about this
run a 10ga wire to the HEI
Jim & Caroline
Yeah it must be at least 10 gauge. The kit is pretty complete with all you need and the directions are a snap for someone that has more than a basic knowledge of auto wiring. My knowledge is basic back to the model A.
~Jim
beltfed,
I think the HEI designation is actually a GM patented name. If I heard that term I would think big old GM style. I would call the Mallory, Pertronix and the rest 'breakerless ignitions' or solid state ignitions opposed to HEI ignitions.
I guess everyone see's it differently though.... smile
Stuart
Stuart,
You are most likely correct as usual but here in the South we do and say things a little differently. When someone ask if you want a 'coke', they don't mean a "Coke-a-Cola". Other places call them dope, soda, pop, or whatever, we just refer to all of them as cokes. Same with facial tissue, we refer to all of it as "Kleenex". Now, where's my cup of 'black joe'? Thanks for the 'heads-up'.
LONG LIVE THE SOUTH! dance
~Jim
