2 members (NJC, Cosmo),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The HEI distributor is new to me. In trying to install my wiring and I am instructed to run a yellow wire if I have a points distributor. My distributor is an HEI. Does that mean it has points. It is easier to ask you guys rather than popping the cap.
~Jim
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Question: Is your new wiring harness 'store bought'? If so, are the instructions for a HEI wiring installation left out? If the answers to the above questions are yes, who built your wiring harness? Thanks
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | See, that was easy and I didn't have to pop the cap and guess. Another Bolt success in the never ending battle against confusion.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The kit is a Highway 22 from American Wire. Yes it has instructions but expects you to know if your distributor has points or not. If it has points there is an additional step to take.
~Jim
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Makes sense to me. The HEI wants to see straight 12V all the time but the points only see 12V during startup then they see something like 9V through a ballast resistor the rest of the time. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | So that's what that "hot" resistor does on my 2N besides just sitting there waiting for me to grab hold of it.
~Jim
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Waldo 53...I have a Mallory small cap HEI on my 250ci. The instructions do call for a ballast resistor. My old OEM HEI did not have a ballast resistor or resistance wire that I can remember. So I would think it best to say some HEI's require a resistor, others not. And yes 'Big Chevy 3600', the resistor drops the voltage during engine run. It is bypassed at start up.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | make sure and there have been many discussion here about this run a 10ga wire to the HEI
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Yeah it must be at least 10 gauge. The kit is pretty complete with all you need and the directions are a snap for someone that has more than a basic knowledge of auto wiring. My knowledge is basic back to the model A.
~Jim
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | beltfed, I think the HEI designation is actually a GM patented name. If I heard that term I would think big old GM style. I would call the Mallory, Pertronix and the rest 'breakerless ignitions' or solid state ignitions opposed to HEI ignitions. I guess everyone see's it differently though.... Stuart | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Stuart, You are most likely correct as usual but here in the South we do and say things a little differently. When someone ask if you want a 'coke', they don't mean a "Coke-a-Cola". Other places call them dope, soda, pop, or whatever, we just refer to all of them as cokes. Same with facial tissue, we refer to all of it as "Kleenex". Now, where's my cup of 'black joe'? Thanks for the 'heads-up'.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | LONG LIVE THE SOUTH!
~Jim
