2 members (Wooley, dt235sd), 153 guests, and 1 robot.
Topics128,102
Posts1,056,532
Members48,448
#456110 09/26/2008 3:02 PM
I am running a relatively stock 292, with the exception of upgraded ignition, a 194ci head (60.5cc combustion chamber), and Langdon exhaust manifolds.
Hoping to run the 2x1 offy intake I have. Wondering if anybody has any carb suggestions for this setup. I have two remanufactured rochester mono-jets, but they seem large and clunky. I'm after a nice clean, simple look. Hoping to run the 1940's chevy truck air cleaners.
I have been considering swapping the mono-jets for a pair of Carters (W-1, 5BR-1, or BB), or perhaps early rochester 1bbl carbs. Perhaps using adapters to use Ford 94 2bbl carbs.
Any suggestions? Thanks
Check out the Holley 847, it is a nice looking carb. It is the one barrel version of the Holley 94 two barrel used on the ford flatheads.
sps Offline
A little trick for your ignition: a 250 electronic dist. drops right in a 292. I have done it, works like a charm.
Steve
I would go with a pair of 2 bbl carbs. The singles won't flow enough to allow the maximum from the 292, especially if you have a healthy camshaft.
Fred
52 3600
69 C-10
