8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible),
57
Mod | | | Forums66 Topics128,075 Posts1,055,919 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 19 New Guy | | New Guy Joined: Sep 2007 Posts: 19 | Hi folks.. I just bought a 1954 gmc 1 ton model 9434 (canadian). When I got it the battery was hooked up negative ground. The truck runs fine this way. Is it supposed to be positive ground? I have had no experience with positive ground so I'm not sure. Thanks for any input. Ward
Elwardo
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Which way does your ammeter show when it is running? Canada GMC's were more like US Chev and could well have a negative ground. | | | | | Joined: Sep 2007 Posts: 19 New Guy | | New Guy Joined: Sep 2007 Posts: 19 | thanks . I will check out the ammeter reading... ward
Elwardo
| | | | | Joined: Sep 2007 Posts: 19 New Guy | | New Guy Joined: Sep 2007 Posts: 19 | Ok I started it up and the ammeter is pointing to C . So I assume that it is a negative ground system then?
Elwardo
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | If it's got a Delco regulator, copy down the part number stamped on it. I can cross-reference a part number to tell if the system was originally positive or negative ground, assuming it's got an original-equipment regulator on it. If it's not a Delco unit, my reference books probably won't be much help. Jerry
| | | | | Joined: Sep 2007 Posts: 19 New Guy | | New Guy Joined: Sep 2007 Posts: 19 | thanks i' ll get the number.. ward
Elwardo
