1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | It has been a long time. Finally, I have sheet metal blasted and primed (epoxy). I have the wood parts for cab assembled and am now trying to fit to sheet matal. Question..Does the seat frame sides fit on top of or in a grove in the floor sills. Question...Do you have to sand the epoxy primer BEFORE painting? If so, RATHER than sanding, can you get a primer or paint that will "burn in" eliminating sanding? | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | I have taken some pictures that may help, maybe. The guy that could help is 35 trucker, you may search his post and see if he has explained some of this before. I was at his house and he was showing me his cab framing and he is putting together notes on the installation of the sheet metal. Look at the pictures, 5 of them and I will try to anwser or take more pictures if needed. Mike http://rides.webshots.com/photo/2384469780101711709dVoJwa
| | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Griz Thanks for the pics. They are a good help. I will try 35 Trukcker. I was able to get a lot of info from a fellow in Penn. James Pain. Been trying him without success. | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | This cab is on its side, but the fire truck doesn't have a rear wall to the cab does it? If you look at KC wood website the are some pictures of a 34 cab being put together. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | The cab is orignal and a rear wall. I believe it is the same as a 34. | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | Do you have any pictures posted anywhere? | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | I have no idea how to post pictures. Is there a trick to the process? | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | Do you have Digital pictures or photos? I use Webshots which is free for the level of use I need. There are many other ones out there that are free too. You can click on my Webshots link and start your own by signing up. It is easy to use and edit if needed. You camera should have a USB cable to plug in and upload straight from the camera. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Griz. I will give it a try. Thanks for your help. Have you or anyone heard from "35 trucker"? | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | John Boy, Here is some information from Tom who is also redoing his wood in his cab. ----
Hi Mike, I’m not quite to that point right now, but here is my plan. Right now I have the new Hinge Pillars fastened to the Cowl. I am redoing both doors right now. Soon to be done with those in a few weeks. Then I thought I would hang the doors, then align the Lock pillers to them. I did not order new wood for the floor and box undernieth the seat. I was able to pattern those pieces and make them myself from the original. By doing this part I am not quite sure how the Pillars will fasten to the base hence the reason I am doing that last part. Then install the roof. It basically lines up the 4 corners of the door frames. Then I can assemble the rest of the wood in the rear of the cab. Following with the 2 wrapped corners, sheet metal around the window, and ending with the sheet metal below the rear window. Hope this makes sense, and I hope this outline is close to being correct. Feel free to pass this on to John Boy, and hope this helps. Tom
| | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Whom ever said a picture is worth a thousand words couldn't have been more correct. I have added a few more pic to my album. I am still in a quandry at the seat. It appears the sides should set down in the grove of the frame sill. In Pic #6 the red pencile sits in the routed grove of the sill. However the side is not high engough to sit in the grove and be flush on top where the seat rests. It appears the sides need to be higher or I need to fill in the grove? Pic #8 shows a little body rust. Is putting window screen or firberglass mesh the best way to fill in? | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | I think that groove may be there for clearance of the gas tank. I will look at the other truck tonight. The floor and seat frame is about the only wood left in that one. But looking at the pictures I am not sure that wood is there either. Mike http://rides.webshots.com/album/559913751gkWZBg | | | | | Joined: Oct 2008 Posts: 2 New Guy | | New Guy Joined: Oct 2008 Posts: 2 | JB...
Very nice pitures of this 35 fire truck. I am looking for a frame for a 35 truck (EB Series).
Do you have any ideas...any thoughts.
I'd appreciate your help. ---Nicole Collier Westmoreland,NH | | | | | Joined: Oct 2008 Posts: 2 New Guy | | New Guy Joined: Oct 2008 Posts: 2 | Dear Mike:
I am looking for a frame for a 35 truck. (EB Series)
Do you have any ideas. I'd appreciate your help.
Take care, ---Nicole Collier Westmoreland, NH | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Ummm . . . how about a '34 Dodge frame? (there's one on e-bay right now . . . ) I'll keep my eyes peeled.  -Michael | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | I will make a contact for you, not sure if the frame is still in the field or what year/modle, will check? | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Well I think I have my profile updated. Test | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | Nicole, I found a frame (DB OR EB) in South Dakota while I was searching for truck parts in August, should still be there. We are both quit the distance. It wasn't bent up that I remember. I have some pictures in my webshots. The cowl was still attached to the frame. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Nicole, the frame I saw is now gone. A fella in Nevada had a parts rig. I will email him. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Nicole No luck on the frame. | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | I am off to a good start. I finaly have the motor BOLTED down!!! I had to make a cross member to accept the motor mounts of the '57 Chevy 6. It turned out nice and fit like a glove. Now I am going to get the engine ready to fire to make sure all is OK. Next is the PTO Viking Pump! It needed a new impeller. I will include a picture of the drive train with new mount and pump install once I hang pump.
