2 members (BC59, Hotrod Lincoln), 186 guests, and 2 robots.
Topics128,162
Posts1,056,937
Members48,458
#456639 09/28/2008 5:41 PM
Anyone have a frame drawing? Or know EXACT measurements for f&r axel centerlines from any givin point on frame for 64-66 sb 4x4? Doing spring and axel conversion and originals were already gone and axel cl was not marked.......Thanks
HELP!!! Can someone measure from front spring hanger bolt back (parallel with frame) to axel centerline. Need both front and rear axel....Thanks
I've got a 65 4x4, but I'll need more specific directions for the measurements you want. Im a real Newb on some of this, and want to make sure I am getting you the right numbers. Can also get you photo's if you need. The only thing that might keep me from helping you out is that my truck has had several mod's before it got to me (different tranny, front axle, motor, etc.). Take a look at my photo's to see if my truck might be what you need, (link at bottom), and let me know if I can help. wave
Give me my Truck, or...my truck daamit! Cause i aint leavin without it!
http://picasaweb.google.com/jadefalcon1218/MyK10
Darn it! :mad: Just noticed the fact that you stated "sb", which should mean "small box". Meaning that measurements off of my "fleetside longbox" won't help any. dang Please disregard the previous "Lame Newbs" post, blush and if you ever need numbers from a "LB", I will be happy to oblige and possibly re-attain my "Superstar Newb" status. Not that it counted for much to start with, mind you. Now I'm outta here, before them "Shop Sharks" start pointing and laughing. !eeeek
PM SENT
PM replied.
