7 members (Jims46, Otto Skorzeny, dt235sd, 2-Ton, tclederman, Bill Hanlon, Millenimech),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | My Dad and I have finally gotten back to working on our 1951 1-ton Panel truck. We have a solid 250 out of a fork lift that we want to replace the existing motor with, because the motor that is in the truck sounds like there's an angry badger trying to get out of the crankcase. I've read about people running into issues with drive shaft length and motor mounts, but what should we expect as far as the firewall and radiator to fan clearance? Also, we were planning on using the existing transmission for the time being. Any thoughts or advice for what kind of problems we might have in these and other areas would be appreciated. By the way, we are using the stock transmission, but we're putting a more road friendly rear end under the truck. Thanks for the help! | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I to am putting a 250 in my 54 3100. My first take is that due to the length of the water pump/pulleys/fan, ect., that it will require a pusher fan and fabricating motor mounts and a rear cross member. I'll keep you posted and can come up with some pic's in the process. I'm setting mine up with 350 tranny. | | | | | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | Thanks, Yakimabowtie. I was debating getting off of my rarely opened wallet and buying an electric pusher for the panel truck as well. As you said, it won't be a big deal to fabricate the motor mounts, I'm just concerned about cutting firewalls and moving transmissions and such. I appreciate your keeping me posted.
P.S.: The other alternative for us is to put a 305 in to replace the current motor, if that is an easier route to take. I'd rather stay with an inline 6 though, because it seems like every classic/custom with 4 wheels and a seat has a small block chevy under the hood. I-6's are unique. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i put a 292 in a 51 1/2T. it's about the same process really. all L-6 motors are the same length, excluding a 302 & 308. the 292 is taller. yes there may be issues w/ fans and i do have a pusher installed now e/w two relays! it's not a big deal @ all.we haven't fired the puppy up yet but we're close. and we did re-locate the rad a bit forward. we fit the engine as FAR back as possible. if you run an auto (we have a T5) tranny you may have to cut some around the cab interior at the tran cover to make her fit back. don't know that for sure, someone else does. http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=579990-R1-020-8A.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=579990-R1-012-4A.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00313.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=8.jpg
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | If you want to run your stock 3 or 4 speed trans you will have to find a bellhousing out of any truck with a V8 from 55-66, or a 63-66 6 cyl. The bellhousing pattern is different between the 216/235 and 250. Later than 66 will work also, but does not include provisions for the side mounts.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | I was planning on dropping you a line, Carolines truck. It looks like you beat me to the punch. Those pusher fans are looking like a good alternative to the old mechanical one we've got. We've already tinkered with the radiator a little, since we managed to come across the heavy duty truck radiator at a boneyard, consequently we had to contend with the 4" thick tanks versus the 3" ones on the standard truck radiators. Thanks for the links to the photos. We haven't had a chance to take the fenders off, so its nice to get an idea of what to contend with on frame modifications. We're sticking with the manual transmission, so hopefully we won't have too much hassle bolting the 250 to it. Dad and I were just going to stick with the stock trans for now. Both of us are wary about putting a t-5 out of an s-10 in a 1-ton panel. It seemed like too weak of a transmission for that size truck. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | use a 54 or 55 1st series bellhousing crossmember with the bellhousing that 55 trackor recommended just make sure it is not a hydrolic clutch | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | I have had a 292 in my 53 1/2 T since 1985, I used a starfire trany,(T5) and a 55 passenger car drive shaft and a 59 1/2 ton rear. Excpt the eng., it all bolted up. I cut the top out of the radiator support and moved it forword. The motor mounts were tricky, I cut them of the frame of the 72 1/2T P.U. I got the motor out of. Hope this will help you. Was starting to think I was the only one who put a 292 in. Glad I'm not. Steve | | | | | Joined: Sep 2007 Posts: 31 New Guy | | New Guy Joined: Sep 2007 Posts: 31 | Thanks again for all of your input, everyone. I'm learning a few new things that I didn't know to watch out for, like what bell housing I'd need and possible cross members to replace my existing one. This is taking a lot of the guesswork out of the install, and I appreciate everyone's responses. They were fortuitously timed, since Dad and I are heading to Carlisle this weekend to hunt for parts. I'll have to add your recommendations to my list of stuff to buy (with some price haggling, naturally). | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | I just got done reviewing the 1951otter photo album. Most impressive, I like Bufflow Steves motor mounts. They are better than what I cam up with in 85. Did he make them up, or get them from someplace? I would like to do the same to my truck. Can you help me out? Steve, [email protected] | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Thanks for the info, my mounts have worked for 20 years but are not that nice and clean looking. The left one has always been to close to the steering box. I'll look into this. Thanks again, Steve | | |
